Off to the emissions man today.. wish me luck!
Done a bit of prep work.
I have no cats! (Dont ask) so I raised idle to 920rpm and temps to 95*C. (hopefully if my 160* thermo lets it get that hot!)
Was going to leave it open loop, but it sometimes it sits a bit too high or low. Emissions here in UK measure Lambda which needs to read 0.997 to 1.030 :Eyecrazy:
So I cant lean it out to kill my HC count.. Also it needs pretty tight control. So Im going semi open loop at the 2 speeds they measure, idle and 3000rpm and have leaned out the switchpoints a tad.
Fingers crossed the cam is small enough to pass without cats. As my next upgrade (Dual 3" exhaust) will rely on the results.
Off to check the wideband AFR.
