#7 installed runs smooth.. Thanks again!
How can I do this with my 06 cummins. Is it possible with the black v2 controller?
I have some kind of that issue, too. After istalling the August 19th update, I lost the balace rates showing up on my pid selector when using the duramax metric.pid. I even copied the balcycl pid in the file by hand, no change...
this is my actual file:
________________________________
[Parameters]
CALC.ACTBOOST=1,531
EXT.TEMP=1,585
GM.BARO2=1,605
GM.BOOST_DMA=1,610
GM.FRPACT=1,695
GM.FRPDES=1,698
GM.FUELQ_MAIN_DMA=1,704
GM.MAINBPW=1,767
GM.MNINJTIM=1,803
GM.PIINJTIM=1,831
GM.PILOTRATE=1,833
GM.TP=1,882
GM.BALRCYL1=1,4425
GM.BALRCYL2=1,4426
GM.BALRCYL3=1,4427
GM.BALRCYL4=1,4428
GM.BALRCYL5=1,4429
GM.BALRCYL6=1,4430
GM.BALRCYL7=1,4431
GM.BALRCYL8=1,4432
SAE.ECT=1,935
SAE.IAT=1,947
SAE.MAF=1,953
SAE.RPM=1,974
SAE.VSS=1,989
Any ideas??
truck is a 04 LB7 with a DSP2 OS based tune...
anyone??? techsupport???
