dr.mike, thanks for the info.
Excellent response thanks
ive installed the WB's and both gauge reading normally, ive set up and connected to the the flash scan (BB logging) for both gauges, both show on the flash scan, only the first has any data, the other reads zero?
Its an E40 PCM, have i missed something?
Attached individually both sensor EQ_RAT11/WO2S11V data is displayed on the V2 ruling out issue with the cable or connection of each gauge, reversed the order of connection still only EQ_RAT11/WO2S11V displays data.
While both connected to the laptop logging strangely EQ_RAT21/WO2S21V is active, when I reversed the connection order EQ_RAT11/WO2S11V is active. Individually EQ_RAT11/WO2S11V is active
Sorted, I thought they were plug n play, I just needed to change the pid entry on the gauges to EFI1 and EF2
Gelf, did you get ot working...?
Need some help, I bought the 30-0334 to be able to log with efi. I have an e39 ecm running a single wideband and the wo2s11 pid connected to my autocal, I have both the ecm and wideband controllers connected under 1 controller with no other controllers connected. When I go to log or display data, the wideband is only streaming data to my autocal for a few minutes then the streaming freezes. If I unplug then plug back in my autocal it reconnects and does the same thing. If I power down my wideband and reconnect it, it does not start streaming again. Why does this only stream for a few minutes?
Or is there a good place to look for this info
Maybe?
