Stock 2002 M6 file and injector help
I bought a used 2000 M6 car that the ECM is just a mess. 2 Bar OS everything is bad for a HCI car. I have a spare 411 ECM but it has an A4 file in it.
I'm looking for a bone stock 2002 Camaro M6 file I can just dump in this and start from scratch with, I've looked all over the net and everything seems to be so old its gone.
I'd also like to ask about injectors. It has 60lb deka injector 1017961
https://www.highflowfuel.com/i-23906...-injector.html
If my math is right they are 82lbs an hour at 58PSI. Do I multiply the IFR table by 2.9? I've never had to scale this big going from 28 to 36 is no big deal. I just need the car to ran good enough to turn everything else. Eventually it will be FI so I'd like to just use them.
Thank you for any and all help.
