Displaying Wideband Serial Comms Data on your V2 LCD
Connect V2 to vehicle OBD-II port (V2 should power on).
Connect V2 to wideband serial port (using null modem cable/adapter).
From V2 LCD/keypad do: F1 Scan Tool -> F2 Data Logging -> F3 Display WO2
You will have to first configure your V2 to read the serial comms from your wideband, do this:
1. F4 Options
2. F1 Setup
3. F1 Edit Settings
4. set Ser Pids to Yes.
5. set COM port to Wide-O2
6. set WO2 Type to <choose your wideband>.
7. for the ECM (e.g. AFR1500) wideband, also set the Id # for each bank.
8. press the Cancel button multiple times to back out of the menu tree.
