1 Attachment(s)
CSP5 Switches Now Shipping!
:jump:
Two versions available. One with a 90 degree OBDII connector, one with a "pass through" OBDII connector.
Pass through CSP5 cables (which allow the use of other OBDII monitoring devices to be used in conjunction with CSP5 switchable tuning) may be installed by removing the truck’s existing OBDII connector from the bracket under the dash by depressing the tabs on either end of the connector. This will allow the connector to be removed from the back of the bracket and inserted into the female plug of the CSP5 connector. The male portion of the CSP5 cable can then be inserted through the dash bracket and the OBDII cable from the auxiliary monitoring device can be attached to the male portion of the CSP5 connector, which will hold the entire assembly in place in the dash bracket.
Pass through pic below.
