L31 ECM with 9 PSI boost Help
I need some help, I am new with EFI live and have searched the forums but have not found the answer I need yet. I have a 98 Vortec with a L31 ECM it has 48lb injectors running at 58-62 lbs fuel pressure (60lbs/hour), pro charger @9lbs of boost, and 383 ci @ 9.1 compression. I have changed the flow rate of the injectors to 7.5 grams per sec and the cylinder volume. Do I scale the VE table and use a 2 bar sensor? I am trying not to use the FMU to boost the fuel pressure. I have played with the PE charts to change the commanded fuel ratio to get to 12.5 to experiment. I could use some experienced help here to give me a direction. Thanks!
