Fan issue settings or software fault???
I do a lot of conversions and harness stuff....
Lately, Ive noticed that even though, I use the Fan Patch, and then set my fans to come on usually at 95c by setting everything above that to 100% and below that to 0%
So after it has flashed, and you suck it back out again, it is set to 84c.... wtf... and the strange thing is, if you open the tune, it is also set to 84c, so it seems to save it wrong
So usually if I reset that gain to 95c, it works ok.... BUT... as luck would have it, on my own vehicle, now using OS 12639270..... (hmmm, Ive noticed a few weird things with this OS over the years...) that with mine, it doesn't matter what I set the fans temps to, the fans come on at 84c, and if you read the tune back out, it has what ever you put in.... whether that be 95c, or 104c... so its giving it the correct instructions but fans come on at 84, and Im not sure if they cycle, or switch off, because its pretty hard to get it below that temp, unless you give it a rest, then if its say, showing 77c, then they will stay off until 84c...
I haven't updated to latest software, but find it strange all the same...
Any help please
