Can we get this fixed in a software release? When you try to adjust by X percent it comes back and ask if you'd like to modify your tables by 0 percent and makes no change.
http://forum.efilive.com/showthread....2993#post52993Quote:
Originally Posted by Alvin
:muahaha:
Alvin,
I could not get anyone to try the calculator and confirm that it didn't work. Your post popped up when I had given up and I found it oddly funny.
Joe
Hopefully they will fix it.. I have to reinstall old software when I want it to work.
I have tried it on my F-body tune files and it gives me a non-zero correction...
Are you both doing this on C5 tune files (transaxle box checked)...?
I pm'd Paul.
Yes, C5 with box checked. You are probably putting in tire size and getting an adjustment for tire size change.Quote:
Originally Posted by joecar
No, I left tire size as is and I only changed the gear ratio...
I also repeated this with Transaxle checked, and it computed a correction of something like 222% to go from 3.23 to 4.11...
that doesn't look right to me...
Joe,Quote:
It probably has to do with checking the box since your car is not a C5. When I uncheck the box I get a crazy number. -.70xxxxxxxxxx
Thanks for trying.
Joe
I'll play around with some C5 tune files.
I tried a 2002 Camaro file, checked the box and got, 222.998014.Quote:
Without the check it came up, -21.411675. That looks right.
It looks like the transaxle calculator is broken. Probably why it wasn't noticed right away
Joe
