March 05, 2011 release candidate 2
The V7.5 release candidate 2 software is available here:
http://download.efilive.com/Software....155_Setup.exe
The V8 release candidate 2 software is available here:
http://download.efilive.com/Software....148_Setup.exe
IMPORTANT: The new FlashScan/AutoCal firmware V2.07.07 is included in the V8.1.2.148 installation. Please make sure you update all your FlashScan and your customers' AutoCal devices with the latest firmware.
This release candidate contains all updates contained in release candidate 1, plus the following:
- Added V7.5 Scan Tool DMA PID support for E39
- Fixed fault: In S&T Black Box Settings, when adding/deleting a pid, after clicking the [<<] or [>>] buttons, two pids get highlighted.
- Fixed fault: In S&T F6: Devices, clicking the [Read] button twice asks to save the file, when clicking [Yes] it says "Cannot create file "". The system cannot find the path specified".
- Added support for E39 OS 12646128
- Corrected a Boost map issue for the Turbo Cruze E78 controller.
- Fixed E39 turbo table calibrations.
- Fixed *.ctd file meta data entries for "Software version" and "Firmware Version" not being populated correctly during pass-thru reading.
- Prevented V8 pass-thru flashing from automatically allocating a VIN license (without asking the user) when programming an un-licensed controller. Now, the user must explicitly click on the [License] button to license the controller before the flash can proceed.
