Hi all,
Would it be possible to get a cax file to modify the E35B Digital MAF tables?
I'm looking to run a new style GM digital MAF with a higher a 12k HZ frequency range. I verified the E35B ECM will read up to 14818 Hz, but table B0205 currently ends at 8696Hz. If supplied a frequency above 9200Hz, the G/s reading falls to zero. So it appears to be running out of resolution in that table. The new style sensors should work fine if table values can be aligned.
-K
Attachment 21083
Attachment 21085
Attachment 21084
