September 2020, Release Candidate 1
This release has been replaced by October 2020, Release Candidate 2. Please see this post for software details https://forum.efilive.com/showthread...se-Candidate-2
ATTENTION - Release Candidate Software
This software contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
The current public release is available here.
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.053 (Sep 25, 2020).
- FlashScan/AutoCal V2 Firmware: V2.07.165 (Sep 25, 2020).
Download here:
Known Issues for RC1:Issue #1
Calibrations that display lists of similar values, (e.g. E38 {C1120} "Freeze Frame PIDs") are not being correctly stored in the tune file. Do not edit/modify those types of calibrations. If in doubt, open the same file and display the same calibrations in both the V7 and V8 editors.
If the values are displayed differently DO NOT EDIT/MODIFY the values.
Workaround:
Do not use V8 to modify calibrations whose values display differently between V7 and V8, use the V7 software until RC2 is available.
Feedback:
Regards,
The EFILive Team
