No dice, I tried them all. I guess i'm sol. I can't spend the money on a scanner that does abs. Ugh.
It pulls the abs codes out of my 2000 ws6...
Of course, I don't want to do anything with the abs besides pull the codes. I can however turn off the TC. I just wanted to pull any codes out of the equinox too. Has the good old abs applying when not needed syndrome.
Not knowing exactly what computer this car has doesn't help. If it is a later model ECM that is on the CAN bus then you are out of luck, your V1 will not communicate with the newer vehicles.
