Perfect thanks for the fast support :cool:
Updated firmware is now available.
Thanks I will give it try in the morning
Huge update
Flashing now works thanks
:jump::thankyou2::jump::good::thumb_yello:
Having trouble with AL5 Transmission controller I previously read, licensed, and modified on a friends truck. I have Tried in V8 and V7.5 software. I update the latest Beta with the firmware 119 attachment in the first post.
The E60 engine controller is no issue. It's only the AL5 transmission controller.
I can not read it,
I can flash it
I can not full flash
When I request calibration details It gives me another error. But when you click ok you get all the details like nothing is wrong.
Attachment 21291
Attachment 21292
Attachment 21293
Can you please locate the trace file that was saved when the trans read or flash was attempted? It will be located in the folder: \Documents\EFILive\V8\Trace
Send it to me paul@efilive.com with a link to this thread so I know what it is about.
Well I was able to read a different 2005 AL5 today so it appears to be isolated to that specific truck. I pulled the fuse for the radio and no luck.
I attempted to read the problem truck a few times with no luck.
I read the other truck which is also registered and tuned on this cable with No issue.
I then went back to Problem truck and reflashed the TCM through TIS thinking maybe something was corrupt. Then attempted another read an no dice.
Other then making or purchasing an adapter for my bench harness, not sure what else to do with it.
Just thought I would update you on what I found
