Hello,
I have had EFI Live on my truck for years now with the 5 position switch. I only tow with the truck 15k-18k My question is, Should I use turbo brake tunes? The truck is stock with stock size tires Crew cab LTZ Dually. Thanks in advance
Hello,
Most will say depends on tune and u have to look at tunes to see but most tunes today the tow tune is setting 4
Way I understand most shop tunes now days is,1-stock,, 2-optimized stock,, 3- tow,, 4- street,,5- race
Still need help finding a reputable shop in Ohio to install brake tune for towing. Thanks
Do you have a V2 to flash in tunes, or are you looking for a tuner. I'm guessing you currently have longhorn since you said it has a smoke tune, and that's there signature tune. If you have a V2, I've got a tune I can send you. And a turbo brake tune for towing is worth it's weight in gold imho. You will be pleasantly surprised at how much less brake application is required.
I'm in south central OH. I do some tuning and could probably help out with a mild tune and/or towing tune, but I'm not real comfortable pushing the limits for a race tune.
