Couple questions about Flashscan reading the PCM
Hi,
First, my car is a 2004 Corvette Coupe.
I went out to the garage to read my PCM and save the currently tuned version, then flash my stock LS1Edit file back, then use Flashscan to read that image to get a stock file in FlashScan format.
When reading the PCM should the car be in a loop of Service Vehicle Soon messages and Reduced Engine Power messages?
With LS1Edit it would set the couple codes at the end that I would have to reset, but not loop through those messages while reading, and sounding the beeping sound.
Also, for a 2004 1Meg file, what kind of read time should I be seeing? I am using a Pentium 4 2.6Ghz Dell Inspiron 8500 notebook. It took me about 10.5 minutes.
Thanks alot.
-Tony
