Is it possible to change the OS in a 98 pcm? The Vets use OS 19980200 and the F-bodys use OS 19980100.
yes it sure is :)Quote:
Originally Posted by TurboVet
Does anyone know how? Is it possible with efilive?
Just open the file with the OS you want to load on to that PCM and do a full relash (the fat red arrow in the tool bar) of that OS. It should write it to your PCM :)
I tried that and it would not load because of the different OS.Quote:
Originally Posted by kbracing96
Humm... You clicked on the fat red download arrow not the skinny one right? Also, you did select the right PCM type too right? (97/98 Gen III) Unless I'm mistaken, it shouldn't care what OS is in it, it should just write the new one over the top of it.Quote:
I tried to load it with the skinny arrow. I will try the fat one. Thanks for the reply.
Ya, that's your problem. The skinny arrow is a cal only reflash. The fat one is a full OS reflash.
Thanks for your help. Worked great.Quote:
No problem ;) :)
