Some more reads would be nice, I've got a 2011 Cruze TCM read (OS 24260649), I don't know how many others are out there though.
I would also like support on the t76
I can get you a read off my '12 T76 if the read is supported. Thanks for your work!
Thanks Brian, I hadn't seen that OS so it must have got lost in the system somewhere, sorry about that.
Boost, we don't have a 2012 Cruze TCM read, so that would be great if you could do that. I know you are running the latest download so you should be set to read it.
As you guys know, when you don't have an abundance of torque the trans needs to be your friend and keep the engine in it's sweet spot.
I'll keep on this one, there's a few Cummins issues that need to be resolved ASAP, but this will be a nice little 'need a break' project.
Thanks,
Operating System 24264426
Just sent it to you and Paul as well. Read went perfect. I appreciate all your great work, we are especially happy with all the Cruze stuff recently. I am pushing 23 psi and 200 torque on a 100% stock LTZ and DARE and Cruze or Sonic in Miami to run it lol. Take care and we look forward to the T76!
lol @ "last programmed by GM"
:P
T76 flashing is done :banana:, now to map out some OS's and we are good to go.
http://download.efilive.com/Staff/GMPX/T76_Flash1.png
yay! been driving a 2011 1.4T Cruze and 2011 3.0L Captiva both with T76 and man do those TCMs need some work.... going by the KR on both these vehicle and the way the TCMs calibrated might have been the same cal team :ermm:
This might be a dumb question, but can we read / do you need TCM OS's from other GM vehicles? I have a 2012 Equinox with the 2.4L 4 cylinder that I "think" also uses the T76 and definately needs a few tweaks.
Id submit as many T76 OSs as possible, seems if EFILive supports a controller they tend to support all OSs on that particular controller. (Hope thats correct Ross! :D)
