I am unable to run scripts....I have tried on both of my computers.
When I go to "run" a script..it goes through the motions, but when I look at the drop down tree, I dont see and blue icons anymore...if i save the file and reopen it..still no changes have been made to the file i was scripting to.
~Les
Just tried to run a script and it also does not make any changes to the file.
I just ran several scripts on a 99 LS1 PCM with no problems. I'll try a couple more PCM's in a few.
Just ran scripts on LS1, E38, LB7,LLY,LBZ, T43(6 speed auto) all worked fine.
Running a existing script isint the problem...creating a new script and running that is the issue i have.
I can script just fine with old scripts..just not new ones.
~Les
I just made a new script on a E38 and it worked. What PCM are you working with?
1 Attachment(s)
Cummins ECM sorry for not giving that info earlier....
~Les
This is what my script page looks like...the blank areas are supposed to have values associated with them.
Attachment 11767
Les,
Is the whole script not working or a few select tables? I have a script that I have created, ran over my stock tune, and the two tunes look identical to each other, but the original tune I created script off of runs like it should, but the one I ran script over doesn't. It's like not all the tables are really changing, only some. But the two look identical to each other in TuneTool 7.5. I thought it may have been the base file I used that the modded tune was created off of. I don't know.
-Andrew
Only a couple tables change when scripted over....none of the timing, quantity, rpm, etc gets changed.
~Les
Kory has been kinda enough to help me with this issue and I'm going to try a plan of attack this evening that might have to do with EFI's scripting routines.
