Just found another bug, Ive never used it before but using the Edit in V7 button in the V8 tune->Edit gives the attached error.
I want to know if the 2013 GMC trucks are supported now ?
WOW, the new dashpage layout and pids are sweet for the e38 and t43, looks like we have a lot more pids now??
Was there a FS / AC firmware change for RC6?
I seem to have lost the ability to set alarms in the V2. Even though the setup indicates the LED's should be in alarm mode, they are stuck in status mode (I get one orange LED flashing all the time indicating vehicle comms).
I think so, Should be dated Feb xx instead of January
Dumb question I know, but I presume you have V7 installed?
V8 used the V7 executable path as defined by this registry key:
\\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Cu rrentVersion\App Paths\EFILive_Tune.exe
If that key does not exist or is wrong then V8 can't start or run the V7 software.
Can you check that registry key on your system please?
Ah I see, thanks for checking it out!
Yes I have V7.5 installed, I do have that reg key fwiw. Full local admin privileges on this machine as well.
