Keep getting a tune switching error code $280
Sent from my iPhone using Tapatalk Pro
how are you switching? using v2 or csp5 switch? If its with the v2 you should check your cables to make sure they are connected properly.
Yeah thanks I found the problem the cat 5 plug had a wire that broke
