I have recently added a 150 shot of nitrous to my truck. It is now crazy fast but i know it can be better. Any ideas on how to make a nitrous tune? I have a log if anyone would like to see!
Thanks guys,
JESSE
Thanks guys,
JESSE
Add a lot of fuel and hang on, but myself, I'd shy away from it or have a spare turbo on hand...
how does the nitrous affect the turbo?
JESSE
Nitrous will give you more boost. Too much boost can cause turbo failure
I think you'll torch the tips of the wheel based on McRat's experience...
So you broke you your gasers tranny, and now you tring to melt you Duramax's turbo with a little spray??:muahaha:
If that gasser is a 2wd extended cab I might know someone interested...
Well...It's a 4wd and now the tranny's rebuilt in the gasser. But the Dmax on the other hand, is goin on its third tranny..oh well its under warranty!!! :banana:
But back to the point...I have been running the nitrous with the Edge on 5 and the BD programmer on "race-only" mode. I have logged up to a 52.2 differance between the baro pressure and the boost pressure on the logs. I have a log of running the nitrous with the BD programmer if anyone would mind taking a look at it?
JESSE
Quote:
Originally Posted by 02gmcwaldoch
Someone is gonna kill a motor shortly. 52.2 lbs boost? is that correct? On a stock 3RD TRANS? Warrantied? NOS? IMHO someone needs to stop and think before they continue down that path. :bash:
i dont know if its correct or not? But thats what it said in the log! I've had the C4 clutches replaced twice. Now I have the BD shift kit and it helps a lot. I've now added nitous and went through a few bottles already and still no problems!
