Those are calc pids...
( if you read post #1 of the Calc.VET thread (which is where they are from) you would know this )
If you're hoping to do Calc.VET tuning using V8 scantool, please note that V8 scantool does not yet have maps implemented.
The PIDs referred to in the Calv.Vet tutorial are in the 7.5 software but not all of them are in the 8.0. I have to use the 8.0 to program the V2. Which means I need to know what the old 7.5 PIDs were changed to in the 8.0. Once I have programmed the V2 with the correct PID to conduct a Calc.vet log i will then take the log file and use 7.5 to complete the rest of the Calc.vet tutorial.
If you mean calcualted PIDs then: click on the [V7] button to add the old V7 calculated PID names to the log file. They won't be used/available in V8, but their names will be stored in the log file and when you open the log file in V7 those V7 calculated PIDs will be calculated and displayed.
If you mean normal PIDs then: select the PIDs as per the Calc.VE tutorial in the V7 software, then highlight all the PIDs and select the menu option Edit->Copy for export to V8. Then in the V8 BBX window, select the correct controller and the right click in the green section and select Paste. That will translate the PID names from V7.5 to V8.
