So, I have 2 serial Widebands and 3 AD inputs. When I plug in the sensors for AD ports, and click record, logging won't start. As soon as I remove
the AD connection, the log starts. Anyone had this problem?
Which V2 firmware version...?
( which V8 build version...? )
Are you logging with V7 or V8...?
What is the voltage range of each of the devices you have connected to the AD inputs...?
Firmware 2.07.91 V7 Build 293. and 0 to 5v.
This update fixes that problem:
https://forum.efilive.com/showthread...ic-Pre-Release
This is the comment about it in the "what's new" doc:
Fixed “Negative Response Error/5” when starting a pass-thru data log while AD1 is connected to a voltage signal of 1.2V or more.
If you need to log the AD inputs before you have a chance to update, you can start logging, pause the log, then connect the AD voltages, then continue logging.
Downloaded. Thanks.
