1 Attachment(s)
Out of range cal in a GM flash?
I have a new 6 speed TCM that I had flashed by a friend who is a service manager at a local dealership. The flash is for a 2006 Silverado with the L18 8.1 gas engine.
The controller itself is an A46, GM part # is 25982143. This part # supposedly supersedes all previous part numbers, so apparently the A46 is the replacement for the A40 and A41. The OS is 24259900.
Here's the output from the Out of Range screen:
Quote:
Out of Range calibration summary: 01:48:44 am, Wednesday Feb 23, 2011
Transmission.Full Throttle Shifts.Upshift
{D5029} WOT 5->6 Shift (RPM), contained one or more out of range values when loaded.
Transmission.TAP Presets.1-2 Upshift
{D5138} 1-2 Part Throttle Off-Going Pressure, contained one or more out of range values when loaded.
{D5139} 1-2 Part Throttle Off-Going Pressure, T/H Mode, contained one or more out of range values when loaded.
Transmission.TAP Presets.2-3 Upshift
{D5140} 2-3 Part Throttle Off-Going Pressure, contained one or more out of range values when loaded.
{D5141} 2-3 Part Throttle Off-Going Pressure, T/H Mode, contained one or more out of range values when loaded.
Transmission.TAP Presets.3-4 Upshift
{D5142} 3-4 Part Throttle Off-Going Pressure, contained one or more out of range values when loaded.
{D5143} 3-4 Part Throttle Off-Going Pressure, T/H Mode, contained one or more out of range values when loaded.
Transmission.TAP Presets.4-5 Upshift
{D5144} 4-5 Part Throttle Off-Going Pressure, contained one or more out of range values when loaded.
{D5145} 4-5 Part Throttle Off-Going Pressure, T/H Mode, contained one or more out of range values when loaded.
Transmission.TAP Presets.5-6 Upshift
{D5184} 5-6 Part Throttle Off-Going Pressure, contained one or more out of range values when loaded.
{D5185} 5-6 Part Throttle Off-Going Pressure, T/H Mode, contained one or more out of range values when loaded.
I attached the .ctd file as well. This is a completely unaltered, as-pulled-from-the-TCM file.
I know why the shift RPM values are out of range - they were deliberately set arbitrarily high by GM to prevent a 5-6 shift under WOT with the gas engine. What I don't understand are the TAP settings. I would think these high values would make bad things happen :wtf1:
