Originally Posted by
GMPX
In all fairness we can't dismiss the non hackable point. The current generation Bosch EDC17 and MED17 ECM's are causing some major problems with RSA checks during reflashing on some of those ECM's. There's just no getting around that unless Bosch give you the private key (zero chance of that), this is why many of the Euro tuners have to pull the ECM's apart to bypass that check which is only done during an OBD-II flash. It'll only get worse as processing power increases, the ECM will have more time to do complex checks before allowing the engine to run. For us GM gas guys at least it looks like we will still be doing this for another 4 or 5 years until the next generation of ECM's comes along.
In the meantime, whoever at GM did the deal with Delphi to supply ECM's for the SIDI motors and not use an MED17, we thank you :thumb_yello:
