Effects on running fuel pressure at 43.5psi....
ok here is the deal...
im gonna run a dry kit roughly 350rwhp total... im gonna use efilive cos5 for fueling.
question is....
I wanna run the racetronix 79# high imp.injectors, but i wanna run them at 43.5psi (what they are rated at), so hopefully it would be easier to tune... can it be done. w/o any issues??.. If I scale em at 58psi they act like a 91# injector. remember its a nitrous car, 2001 corvette
Fuel system will consist of....
racetronix 255lph intank w/ hotwire harness
a&a return style front mount FP regulator w/ 97 vette fuel filter
KB boost a pump
according to my math its gonna take 331lph to support the hp I wanna make, according to KB the boost a pump boost's the fuel pump's out by 50%, so if there is any truth to that combine my pump w/a boost a pump it and it should flow 382lph...
so pros to running a lower FP
1. makes a larger injector easier to tune
2. allows the pump to flow more volume.
3. the injector flows what it is suppost
cons...
1.will the motor function properly....
cant think of anymore...
