Originally Posted by
Craig Moates
Oh my....
The RR is capable of emulating up to 1024k. It doesn't care what PCM it is installed into personally, but it does provide some info to the software side so things can be done a bit more judiciously.
The first 2 digits of the serial number indicate the 'intended' or 'installed' usage. This is typically either 01 (for 512k) or 02 (for 1meg). This is almost entirely specified in order to facilitate correct OS matching etc with the target device from the software perspective.
EFI Live uses this part of the serial # to determine what types of binaries/tunes it should be allowed to upload. This typically will help to prevent confusion. As folks swap RRs across multiple PCMs, that goal won't necessarily be achieved.
I don't believe TC has a 'check' in place on the serial # to try and determine PCM type. The 'check' or the refusal to upload/sync from EFI's side can be worked around I believe, contact Paul or Ross for details on this if necessary.
The V6 is a different animal, mostly 512k but still not identified via 01 or 02. I think I have a placeholder in there like 04 = 'other'.
Keep in mind that uploading a file into a RR that is installed into a DIFFERENT type PCM than what the file is intended to be functional within has no hope of working.
Also, on the FW 12.13 -> 12.14, the only difference is a modification to smooth out the RTACS. With 12.13, it would occasionally hiccup a bit. No other changes.
Hope this helps,
Craig
