Any way with the current software to get the vane position correct without the support of additional .cax files ?
Quote: Originally Posted by staytuned Any way with the current software to get the vane position correct without the support of additional .cax files ? No one table exists. It uses a calculated algorithm bases off of desired air models.
Quote: Originally Posted by Road No one table exists. It uses a calculated algorithm bases off of desired air models. Mine is no longer running in closed loop.
