FlashScan V2 Wiring w/Innovate LC-1
Hi all,
New member here, I had the LC-1 installed and the yellow & brown analog wires run to the glove box last week. The LC-1 I bought didn't have a green analog ground wire per EFILive's LC-1 Installation Guide, it only has six wires.
I called diynoob (Tony) at MPH and he confirmed that I needed to run two more ground wires from the common ground point (where the blue and white grounds are located). So the ground wires have been run to the glove box and one ground was connected to the two-hole orange connector along with the yellow analog wire. The other ground and analog will feed to a DynoTune AFR gauge when it arrives (hopefully today).
Anyhow, the LC-1 install guide only has a picture of the V1 device, so where exactly does the connector fit on the V2 device and can someone confirm the orientation of the two wires themselves in the connector?
A picture showing a working V2 device with the two wires connected via the orange connector would be most helpful.
Thx,
-X-
