This is the sensor calibration I use
140.000000
104.062500
76.250000
60.000000
48.984375
39.921875
32.148438
25.312500
18.710938
13.203125
7.656250
1.210938
-6.601563
-14.375000
-24.179688
-37.812500
-40.000000
140.000000
104.062500
76.250000
60.000000
48.984375
39.921875
32.148438
25.312500
18.710938
13.203125
7.656250
1.210938
-6.601563
-14.375000
-24.179688
-37.812500
-40.000000
Thanks Highlander. I will give those a try.
Thanks for sharing this Highlander.
What program do you use to make this an actual CAX file? Can I use a text editor and then replace the coding with yours and then change the extension to CAX when done? Seems too easy that way, but thought I would ask. Can you have multiple tables added in one CAX (B9996 and B9021 for example)?
Regular notepad
i use notepad++
Great, thanks! And combining coding into one cax file shouldn't be an issue?
No. Each parameter/table/function is separate. As long as its compatible with the os, you will be fine. My cax for this os is 600kb big. And the one for 12587603 is 12mb!
My small contribution. I used this and made it work for 12593358 / 02040003. In prep to convert to LS3 card MAF.
Code:[B9996]
; Description
DESC.001 = IAT Sensor Calibration Table
DESC.002 =
DESC.003 =
DESC.004 =
DESC.005 =
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 2 "IAT Sensor Calibration Table" "IAT" "" 1 2 0 0
; Address(es) BitOff Bits Typ Inv
ADDR = E3BE 0 16 SNM 0
; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
SI_SLOT = "C" 0.0390625 0 3 -100 284 -100 284
IM_SLOT = "F" 0.0703125 32 3 -148 543 -148 543
; Body Col Row
ULABELS = . . .
; Enumerations
SI_ENUM = .
IM_ENUM = .
; Units Labels
SI_COL = "C" "C"
IM_COL = "F" "F"
SI_ROW = "% A/D" "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50.00,56.25,62.50,68.75,75.00,81.25,87.50,93.75,100.00"
IM_ROW = "% A/D" "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50.00,56.25,62.50,68.75,75.00,81.25,87.50,93.75,100.00".
I switched over to LS3 MAF today and found a small issue with this if you use Farenheit. Need to change the "offset" to "32".
Thanks aaronc7.
