7.5 LMM DPF delete and EFI V2
I have been trying, unsuccessfully for the last several months, to keep my truck from setting a check engine light "CEL".
I have a V2 and am running version 7.53 and the latest firmware. I have been working closely with an EFI vendor who has been trying his best to help me solve my problem. I am on my 7th tune revision an even one supposedly from Ross at EFI, still with the same result. Since I don't know who else to ask and seem to have run out of options to try, I thought it time to post here and see if there is anyone who can help or have any suggestions to try.
I guess I should begin by detailing the procedure I follow.
1. Start the EFILive V7.5 Tune Tool
2.<Help><Register efilive> enter the provided numbers (only on the new version)
3.<File><Open tune file> select the tune file that I received and put in the Bins folder.
4.Plug in the scanner to the laptop
5.Plug in the tool to the truck
6.Turn the ignition to the run position
7.Turn off my lights and heater fan
8.Click the door latch to the closed position to stop the dinging
9.Select program PCM with currently loaded program
10. Click the check status button
11. Select start and wait for the program to complete
12. Turn off ignition, click ok and wait for the countdown to finish
A few things I have noticed about the behavior of my truck:
Seems to run great until the CEL comes on, after that it still runs fine but the truck exhaust note changes pitch up and down when it is idling a hiss to a drone to a hiss. It may be me but it also seems to run a bit more sluggishly, not really noticeable unless you really pay attention, very slight, could be my imagination.
[B]The scan tool will not clear the CEL. It will clear the codes, and when I tell it to upload the codes after I clear them, I only get the P0000 ones, but when I turn the truck on the CEL is still there and stays until I re-flash the ECM.
I have had it set 5-6 times so far usually after about 2 hours of operation coming home from across town (15.min drive). The truck has reached operating temperature and I am pulling the moderate hill to my home, although it has set it while idling. The truck has usually shifted into 4th or 5th and is cursing about 45-50mph at around 1400rpm, near the top of the hill "bing" the light comes on.
I have the sensors disconnected from the harness and a turbo back exhaust installed. Other than the different tune the truck is stock.
I would really appreciate any feedback or suggestions anyone might have. I can make a copy of the current tune I am using available if anyone would like to take a look.
Thanks in advance for you help,
Fred
