Hey guys what are the PID's that I would want or should log after my cam swap. I had the PCM tuned by Wait4Me performance and want to make sure everything is ok. I have a LC-1 but it's not configured to my laptop yet. Thanks
Open your scanner. Go to file>scroll down to open>Double click on open PID selection file... Then I usually use the Default Imperial.pid
That will give you the basics that you will need.
For example:
VSS
TP
RPM
DYNCYLAIR
DYNAIR
MAF
MAP
IAT
ECT
AFR
SPARKADV
KR
LONGFT1
LONGFT2
SHRTFT1
SHRTFT2
HO2S11 (not HO2S12 or HO2S22)
HO2S21 (not HO2S12 or HO2S22)
FTC
or replace those four with these:
IBPW1
IBPW2
CALC.INJDC1
CALC.INJDC2.
And also your wideband pids...
Wideband analog connection:
CALC.AFR_LC11
CALC.BEN_LC11
Wideband serial connection:
EXT.WO2AFR1
EXT.WO2LAM1
EXT.WO2EQR1
EXT.WO2ST1
CALC.BEN1
