Custom Operating System Questions - Compatibility, viewing parameters
Hello,
I am a newb in the sense that I have never even used EFI live (although I have opened a stock TBSS file and scoured it for a few hours). I have HP Tuners now. I am a hobbyist/enthusiast, not a professional. HPT does NOT offer a custom OS for my vehicle. I have finally met a limitation of the OE OS that I think is a little lame.
When the ECM commands open loop for power enrichment, I want better control of the fuel and air ratios based on load, not just speed. PE is basically an on/off switch with some control of air/fuel ratio for engine speed. The OL gain tables would be great to use, but based on what I know, these are used only for warmup enrichment and PE is the authority when exiting closed loop after warm up. Boo.
Anyway, how do I even tell if EFI Live has a custom OS for my vehicle, and secondly, can I open the file and examine parameters and get familiar. Basically, I am not going to spend $900 unless I am damn sure it will do what I want...
I looked on the EFI live site and through the forum pretty thoroughly. Didn't see any chart showing a list of vehicles, etc. Or even how to go about this.
2008 TBSS - E67/T42 - VCM OS ID: 12618164, TCM OS ID: 24239927
Stock LS2 with TVS1900 and 3 Bar MAP: GM 12592525, Blade MAF: GM 15865791.
Thank you!
