I'm not sure what you mean...?
The axis is on kPa...
post a screenshot of what you're seeing.
~ posted by phone ~
under l96 i see labels from 128 to 768. the values in the tables are different. but i probably misunderstend something.
So if rail pressure measures 400 kPa (58 psi) (i.e. gauge pressure is 400 kPa, so absolute pressure is 500 kPa)
then injector pressure delta = 500 - MAP
so then the usable range of the axis on B4001 are as follows:
- NA: 408 to 468 kPa (400 kPa has to be interpolated by ECM)
- 1-bar boost: 308 to 468 kPa
- 2-bar boost: 208 to 468 kPa
Yes 58 psi.
You can scale the IFR table using by multiplying by sqrt(44/58).
That makes a large difference. Thanks for the formula!
58 to 44 is a 12.9% difference.
Can rail pressure affect Minimum Injector Pulse Width? I realize it's a measure of opening time, but it seems like the volume injected at a lower pressure would be less within that time and a compensation could be to modify that minimum time.
Yes, scales by 0.871.
It can... I don't know how to calculate the new minimum.Quote:
