2 Attachment(s)
Need to verify stock tune for new TCM
Truck had trans rebuilt. In doing so the valve body and TCM was changed on the 6L80e in a 2009 5.3 Silverado. Original TCM OS is 24249179. New TCM that was sent for the rebuild is 24239353. Based on the compatible function these two OS are not compatible. Went into the drop box and found a 2007 Denali Truck 6L80e tune with matching OS for the new TCM and full flashed into truck via V8. Truck works as it should however it has developed and harsh shudder on the 1-2 shift only at 2000-3500RPM. This is after driving and getting fluid warm. EVERYTHING else works perfectly. Tune is factory 100% other than VIN change for full flashing. New TCM was "empty" before the full flash with the 9353 OS. Can someone verify that tune should work for this truck? If not would someone have the correct tune for it or is this a mechanical related issue? Torque Converter was changed at time of rebuild to new stock. Attachment 23869Attachment 23870
