What is an acceptable oil temperature range for an LSx 455 with 7.5 PSI supercharger? I'm running 220-230 degrees crusing and 250 if I drive aggressively for a period of time. Not sure if that is too hot or ok.
Thanks,
Bobby
Thanks,
Bobby
20F-30F above coolant temp is considered good.
For hard driving, 250F is still considered within acceptable range.
What oil are you using...?
40W Valvoline Racing Oil
Mobil 1 is fine in those ranges and probably most full synthetics.
The Corvettes throw a warning @ ~290.
