In search of a known good base file. OS doesn't matter but do need it to be able to convert over to a CSP file, please.
I have all basefiles, If you know the exact number I can get it for you.
Thank you
Seems the CM2350F single tune file won’t open in v7.5 anymore, most recent software update. The CSP4 versions open though. Anyone else experience this?
Newly supported operating systems are only supported in V8
Sent from my iPad using Tapatalk
Which file are you referring to? The one posted above or a different one?
Cindy is correct in that new OS's are only being added into V8 from now on, however there hasn't been many (maybe any) for the CM2350F added since we made that decision (the last OS addition for CM2350F was Feb 2020).
The 2018 OS release run down is like this:
32.18.01.00 - Supported
32.18.02.02 - NOT Supported
32.18.03.03 - NOT Supported
32.18.04.04 - Supported
And that is just a timing thing that the middle two got replaced pretty quick, by the time we got around to needing to map them 32.18.04.04 was already out and being flashed into vehicles by the dealers.
The 32.18.01.00. I used to be able to open it in v7.5 now just the CSP version will open. Had the 32.18.01.00 open in v8. Thought maybe something was wrong with my copies or something.
I have the V7.5 version posted HERE installed and that file above "32.18.01.00 - DO90066.03 32370831AD 2018 DJ D2 6.7L 68RFE 50S CM2350F.ctz" opens up just fine.
What is the message on the screen when you try and open it?
I got the .34 version installed. The above file gives me "Unrecognized PCM" message as does all my copies and even when I xCal the DO90066.03. I'll update to the .35 and try it.
