Sorry, I misunderstood your previous post. I have the limiters all tweaked! ;)
I completely understand Kory. How does the ECM know how much fuel we're flowing..hmmm...maybe a calculation? (rhetorical question). Now that being said, how does the ECM know duration...injector opening time! Hard facts is how it knows. Thanks Kory.
-Andrew
That is accurate with stock injectors. If you have larger nozzles, then the actual maximum volume can be higher than commanded. What is important, though, is that the commanded volume is a reference.
Ultimately, I think it may prove to provide some benefit if one was able to accurately modify the volume axis for the exact injectors being used. This would require a flow sheet of the injectors with multiple pressure and volume points.
did some tweakin today and like all of you said before...wow! didnt get to log anything, but it fueled hard up to 3400 + rpm and it didnt hesitate gettin to 1400-1450 deg. for egts. not tooo bad of a smoke screen neither. still have some more to mess with, but what a difference. thanks for the info guys and for the info above kory. will get some more info up on wednesday. take it easy
denny
Glad to see these things opening up...the sled pulling vids on youtube are getting exciting now that we have full fuel :-)
