Known issues with Jul 12, 2014 release of the EFILive software and firmware.
Currently known issues and possible workarounds for the July 12, 2014 release of the EFILive V7.5.7.261, V8.2.2.256 software and the V2.07.63 FlashScan and AutoCal firmware.
Issue 1:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
T43, T76 and A50 controllers do not use the correct controller serial number when using a VIN license prior to flashing.
Workaround:
None. Fixed in next update.
Issue 3:
Deleting a controller entry in the [F5: BBX] window may cause an "Access Violation" error.
Workaround:
Issue 4:
Loading a data log file in V8 may cause an "Access Violation" error.
Workaround:
Issue 5:
Loading E86 (LML) *.bin files does not work in the V7 software.
Workaround:
Load the E86 *.bin file into the V8 software, save it as a *.ctz file, then load the *.ctz file into the V7 software. Fixed in next update.
Issue 6:
Some labels were wrong on E86 (LML) GMLAN tables for non-US calibrations.
Workaround:
