Just did some logging and trying to playback the results with the chart. I can see the PID results playback (in the data screen) but cannot get the charts to work. Any ideas? :nixweiss: Thanks.
Chris
Chris
Nevermind, figured it out.
Can you see the charts when you hit F10 and then 'B'? As long as you're viewing a chart that displays a selected PID for that log, it should work during playback. If the PID listed on the chart has a line through it, it wasn't logged. You might have to Right Click on the left or right side and use a selected PID under the Metric, Imperial, or Other PID sections.
On the Dashboard (F10) tab, select B.
Then right click somewhere in middle of window, and go
Add->Chart->New Chart or
Add->Chart->Theme: Default->Imperial1
A chart should appear, you can resize/move it if you want (grab with mouse);
repeat 4 more times;
then do right click in middle of window and go Dash Settings->Tile Charts.
Then right click on any corner of the chart,
you will see Metric, Imperial, Other, choose one,
you will see a list of PIDs,
choose the PID you want;
repeat on other corners of chart for more PIDs;
Now go either
File->Save->Save Dashpage or
File->Save As->Save Dashpage As
Edit: oh, I'm too late... :lol:
