Yes, MAF DTC's must be enabled... either 1-Trip or Non-Emissions.
I don't remember if the transient filter comes preconfigured... let me pull it up so you can copy.
Yes, one region at a time... keep throttle movements slow and to a minimum, use the brakes to load up the engine if necessary.Quote:
So should I try to focus my datalogs on one area of the map at a time? I have been trying to get 25ish minute long datalogs with a lot of varied MAP and RPM values to try to get the most thorough results. I may need to modify my method.
