Comnrailpwr thanks, there is 3 different ones would any of them work iam trying some new tuning and can't find my original tune file, but so I should be able to download the file to autocal and load onto my truck right? Thanks again
Generally on the 3rd generation trucks any file will work as long as auto is used for auto, manual file for manual and aisin file for aisin.
No. The autocal can only flash files from the tuner who created the original file for it. The autocal is linked to that flashscan and the files that the autocal can flash must be linked to that flashscan. To do your own tuning or use tunes from multiple sources you need a flashscan.
Sent from my SM-G960U using Tapatalk
So are you saying you could use a tune for a pre egr dpf 3rd gen and load it onto a 3rd gen 6.7 and it will work/also be deleted?
