Originally Posted by turboberserker
Guess I should weigh in here... I think MN-C5 and I have the same year and model. My COS#3 worked fine, but I applied the cal file and then created an in-between flash file, and applied my changes over it. I'd read MN's post before hand so I looked for damaged tables first.
Don't have the laptop here or I'd give you the cal / tun numbers I used, but I took them directly from the chart for my OS (and actually I was just putting up the #3 version of the OS I was already using as a #1).
It did take awhile to get her started but I get the same thing anytime I zero the trims, so I did what I also do -- used the idle controls the first time to get her warmed up. After that, it was all good and no more hard starts.
