1 Attachment(s)
shift rpms tis rpm or engine rpms
doing a 98 camaro with a stall converter and cam will not shift on 2 to 3. it worked fine with converter only car. now with cam it will not shift 2 to 3. on a log i took looks like it shifts off tis rpm not engine rpms.it seems like people are allways having problems with shifting. i can see where a loser converter would make things crazy because converters are tighter with lower gears. so the 1 and 2 shifts converter is more locked up so the tis rpm is higher in 2 gear tis rpms could eazly be lower making it not reching the set rpm shift point.hear is a log my vss shifts are set low so it uses rpms.my rpms are set at 5650 in the log looks like 1 to 2 shift 5650 @ tis and 2 to 3 tis never makes it there with out engine speed hitting limiter.i dont have the car right now to do more logs looking for ideas befor it comes back to be finished.also like to see if anyone has a log with a convert and pids tis,tos,tccslip,engine rpms and what there shift points are thanks
