Yep i get the just of it. I will have to play with it until i get it fixed up
Sent from my iPhone using Tapatalk
Yes, just gradually increase the lower temperature cells of {A0008} until you get consistent AFR as it warms up. That table should end up as a downward slope as temps increase.
Ok i will give it a shot when i get home from work tonight. Thanks again
Ok so this thing is still doing it. I have been doing some reading on other sites and some guys running way bigger injectors than me are having no issues maintaining idle using hp tuners. They recommend lowering the min transient fuel table but it doesnt look like we have that table and to change the injector timing with the spread sheet. I read the sticky on b3702 table but not sure exactly what to do there. Can one of you guys point me in the right direction?
Post tune/log files.
Can i attempt to run closed loop off of one o2 sensor? My one manifold has a bung in it still and i can swipe an o2 sensor off of one of my spare engines.
No, CL requires both front O2 sensors.
Ok thanks Joe. I guess ill try to put another bung in the passenger side manifold and run 2 o2s since i cant get this thing to work right in ol
