411 swap cmp -40*
Hi,
I have a 98 Tahoe 5.7 with a 411 pcm and just got my V1 commercial so I did a relearn and everything is running fine. When I checked the CMP retard(vortec) it read avg -40.75.
I tried to adjust it by moving the dist. one tooth forward and then it read between -80 and -50. Then I tried the reverse direction and was able to get -35, so I moved it back one tooth and tried again and it wouldn't start at all. I ran out of time so I just put it back where I started at -40. It starts fine and doesn't throw a code, so is the scan tool reading incorrectly? Or is it really -40 off and I just need to try again?
Maybe I'm using the wrong PID but I didn't see any others that seemed correct.
Hello 9851Chevy,
Have a look at this thread regarding Camshaft Position Retard …
http://forum.efilive.com/showthread....osition-Retard.
I believe zero (+/- 2 degrees) is the required tolerance ...
Regards,
Taz
If I move the distributor closer to 0, it won't start at all just back fires. That is why I am wondering if the displayed value is incorrect or if something else is wrong.
I rarely work with the Gen I based Vortec engines. I was merely trying to point you in the right direction. You may want to send a PM (private message) to Forum member “ZR2_350” who started the thread linked in post #2 above. He finally got his camshaft position properly oriented, and appears the engine ran well afterward.
Regards,
Taz
