Received un-linking instructions and my AutoCal device must be using firmware V2.07.104 or later. Can I reinstall previous firmware? Where would I find it?
You cannot downgrade firmware, as long as your firmware is newer than this version you can un-link it. This functionality never existed prior to this firmware update, so even if you could go to an earlier version (which you cannot) you wouldn't be able to un-link. Current firmware is 2.07.139 in the latest software (Feb public release). Download the V8 software and upgrade your firmware, then you'll be able to un-link.
Truckcancer. were you able to get this resolved? I'm having the same issue.
I've tried that and it still wont work.
I am having the same problem. Any answer on this?
If you meet the firmware requirement, the most likely issue is you have a space at the end of your code.
If the code does not function, please speak with your tuner so that they can generate you the right code.
Cheers
Cindy
