Yes, with MAF DTC and/or KS DTC, you will be running from LO Spark table.
Don't lose your will, just keep chipping away at it...
Think of it like this: if you don't do this, what else is going to occupy all your time (any free time will be claimed by your wife) :)
thanks Joe,
Ok my setpoints are 365,435,435,435,450,500,500,550,550 for both banks, would dropping these by say 100?? would this lean my engine out and increase lamda to 1.02??
Need to play with readings to set idle and also the fast idle...for the emissions tests
Also what do i have to do with table B4107??
0.000000
4.000000
12.000000
30.000000
36.000000
40.000000
44.000000
50.000000
54.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
64.000000
etc etc
Gavin
I wouldn't do that. You can get your high idle leaner by adjusting B4107.
Try something like this...
0.000000
4.000000
12.000000
16.000000
20.000000
24.000000
30.000000
36.000000
44.000000
52.000000
56.000000
60.000000
64.000000
with 64.000000 then continuing all the way to the bottom of the table.
Hello,
ok i need to prepare a few tunes before i go on the 7th oct as the tuner will charge me per hour. So why not adjust the switching points? Or is there something different with my current table b4107?
if i do a log prior go the 7th would someone be able to have a quick look at my timing as well to see if this seems abnormal or anything...?
Thanks all for the help so far.
regards
gav
Hi,
anything else i could prepare or do?
regards
gavin
Post any logs you take, we'll look at them.
statesman's suggestion of making B4107 less steep causes the lower part of B4105 to be referenced where the mV is lower.
Ok thanks both will try that on the 7th. Will try to do a log on sunday with parameters that may be useful.
much appreciated though.
regards
gav
Hello,
Ok have done an idle log and a fast idle log.
Do i need another MAF pid as the 1.58 doesnt move, or does this default to predicted anyway??Attachment 20261Attachment 20262
Gavin
Those logs won't tell us very much... we have no idea how well your cat converters are cleaning up the switching events. If you still fail the sniffer test, then you might have to go open loop to pass.
