August 05 2022, V8.3.28 Public Release
Full Release Notes:
Version Numbers:After installing this release you should have the following software and firmware versions installed:
- EFILive V8 software: V8.3.28
- FlashScan/AutoCal V3
- Firmware: V3.00.096
- Boot Block: V3.00.006
Download here:
Known Issues: Issue #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
Workaround: EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
Issue #2: The "What's New" document shows the EFILive V8 software version as V8.2.28 instead of V8.3.28.
Workaround: Just assume it says V8.3.28 :).
Issue #3: When Flashing CMF (CM2450B) controllers using FlashScan V2 in standalone mode, the progress meter does not update/display the progress of the flash.
Workaround: Ignore the progress meter. Will be fixed in the next update.
Issue #4: When using FlashScan V2 in standalone mode to display trouble codes, selecting the "EPA Current DTCs" and/or the "EPA Pending DTCs" options does not display any trouble codes - even if trouble codes are active.
Workaround: Use the V8 software option: [F4: OBD]->[Read] to view DTCs. Will be fixed in the next update.
Issue #5: For some E37, E38 and/or E67 operating systems, the data in the "High Octane Spark Map" {B5101} is displayed as raw hex values instead of degrees from top dead center.
Workaround: Download the file:
E37_E38_E67_B5101_fix.zip and unzip the contents into the folder: \Program Files\EFILive\V8\cam overwrite the existing files. You may need Windows Administrator privileges to copy files into that folder.
Issues #2..#5 have been resolved/fixed in the latest beta release available here. Regards,
The EFILive Team
